Modifying my 1950's fireplace with brick chimney to accept a wood stove and want to tackle issues one at a time.  I need your advice please.....
I removed the old iron throat damper today, but left the damper's structure in place. The removal of the swiveling throat- which never really "sealed" very well, left a space 28 inches wide by 6 1/4 inches.
In anticipation of a liner and block-off plate:
1) If I will purchase a stove with a 6" flue, how large do I have to make the throat's opening for the liner to fit through? Please note that:
a) My chimney is only 10 feet from the throat to the top of the square clay tile exhaust, so from reading here, I will need to ensure a liner that will give me the best draft.
b) It will be a Class A liner- but should it be solid double-walled, or flexible with insulation? I have been saving my pennies and will spend whatever is best for my situation.
c) I assume I will have to "extend" the chimney to at least 12+ feet if I want to install either an Englander 30 or the Drolet (both fine stoves and I will be buying one of them).
2) If I have to enlarge the opening from 6 1/4 inches to 8 or 9 inches, I can do that by busting up some of the mortar used to secure the damper structure to the brick fireplace. I will then remove the entire iron "base" structure that the throat swiveled from. Can I still secure a block off plate without any damper "structure" remaining?
3) I like the idea of a solid chimney liner, but the throat opening of my existing 1950's brick fireplace is a full 8 inches forward of the center of the clay flue opening (12" x 12", by the way) at the top of my chimney. Is there any advantage to using solid liner above the throat opening, and transitioning to flexible liner for a gentle bend to meet the top of the stove? Or am I over-thinking (never happened before
I thank you all for this site- the pros and the "newbies", and the moderators. I am half watching the Super Bowl and half reading thread after thread here!
I will start a "build thread" this week....step by step, inch by inch, mile by mile.....thank you!
)?I thank you all for this site- the pros and the "newbies", and the moderators. I am half watching the Super Bowl and half reading thread after thread here!
