Not a bad idea for a one room cooler
https://www.youtube.com/watch?t=110&v=FaC0dlRENk0
Why insulate it? Any heat absorbed by the ice would be coming from the space around the bucket anyway. Isn't that the intent anyhow?
Won't it result in humidification negating the benefits of any cooling?
Did you note the 49F measured output temp? Humidity increase would be minimal using frozen water jugs and bottles, and ice packs. Looks more like 16-18 lbs. but that would be a guess. The cooler looks like it could hold a lot more.Creative but I'm skeptical to say the least.
The power used to make the ice and run the fan as Grisu mentioned?
Just did some quick calculations and came up with ~1800 BTU that 5 kg of ice (~11 lb) could give you as cooling capacity. Not sure if someone will really notice that. The air movement due to the fan may be what people actually feel as "cooling".
(P. S. And you better buy the ice at the store or the increased load on your freezer will be actually more than what you gain in melting the ice again.)
Good luck finding a $65 A/C. Lowest I have seen in a long time is around $135.
