raising the stovepipe hole in a masonry chimney
Easy enough, but I’d be getting a big trim ring.
so it has a partial liner? I read back through and I don’t quite understand what metal is already in place.
Quote" Turns out the liner is rectangular cross-section metal. Would make raising the stovepipe hole more complex, I imagine." Back on page one. Also on page one the attachment Inspection Report shows a metal liner (pic) although maybe we though it was clay...
I have never heard of this before .I wonder if it's a covering on the clay liner?
Rather than relying on the report, can the homeowner log on here and provide a better description and pictures of the situation? We need more info, like the liner height, actual ID of the current liner, current setup with pictures, is the brick face at thimble location exposed or is there a wall it passes through?
Not into forums, but I am their neighbor and can do just as well. That being said, I don't know most of the answers (yet), except that yes the brick is exposed inside the living room (so at the thimble). See pix in post #24 attachment.
Note also that the inspection document (attached to post #2) says "lining height 35". I have no idea what that means. Inches ? Starting from the chimney cap coming downwards ? Does this mean perhaps the new higher hole for the stovepipe thimble doesn't need to penetrate metal as well as brick (it's certainly more than 35" below the chimney cap) ?
Each piece was 35+ inches and then put together for the full run? I still have not heard if anyone has seen this system before, and what is behind the metal? Standard clay liner? Was it used before circular SS Steel liners we available?
Little followup on this ... today they got their chimney cleaned and re-inspected by the same company. This time they stated that there was dangerous creosote buildup, but probably ok for the remainder of this season.
Couple of useful pieces of info though: the cross section of the chimney is about 13" square, so tons of room for a stainless liner. Also, the liner is clay, not metal - so not as difficult to raise the hole for the stovepipe.
They also understand they plan to buy a BK soon, and are definitely recommending a liner. It'll be interesting to see what their quote is. They seem very reluctant to raise the hole and don't think it's necessary, despite the BK materials clearly stating that the stovepipe needs to go straight up out of the stove for 24"; they're going for the short configuration of the Princess, which I think might give them 15-18"
Reactions: Whitenuckler
If it doesn't flow well, they were advised. Thank you for helping.
BKVP
Reactions: RustyShackleford
