Hi all,
I recently acquired a Jotul F118 Black Bear (Manufactured in 2008) and have disassembled it completely. The top baffle was warped and both side baffles had hair line cracks. I have ordered the new baffles, new gaskets/glue, Hearthstone cement, and Stove Bright flat black paint. After some grinding, it should be ready to restore. The cement requires a slow heat treatment to cure as does the Stove Bright paint. Does this have to be done day of application? or will waiting until I am done assembly (which will more then likely take me longer then a day or two) be fine? I have read on previous threads that the cement can crack if it sits to long with out being heat treated.
Part two...
I plan to paint each panel separately and then assemble. Will the paint effect the metal-to-metal connections where cement is required? Should I paint the whole piece once it is whole?
Thanks!
Austin
Part two...
Thanks!
Austin
