by grenade piece of junk, do you just mean one that you've mushroomed out through use, or is that actually some sort of wedge?I keep (1) grenade type (piece of junk) and (3) strait blades wedges, I like the strait blades because i can cut a 2" deep groove with the chainsaw and put the wedges along the same path and work them all together (talking about splitting +35" wood)
+1 for having at least 3 wedges. I prefer grenades because they're easier to start and less likely to bounce out, but I also have regular flat wedges for opening up splits in tough rounds. I have a couple of these grenades and they meet most of my needs:You need a minimum of three wedges. Two to start the split and one to get the other two wedges out.
Just kidding. Sort of. But do not undervalue the usefulness of a stob.
What’s a stob?You need a minimum of three wedges. Two to start the split and one to get the other two wedges out.
Stob (n.) A small, straight piece of wood. Stake. Post.
In wood harvesting a stob is a small limb cut to the desired length with a wedge chopped on one end. You use it just like a really big wedge to force the log apart once you have a split started with your iron wedges.
They are typically made from a two to three inch limb about 18" long, but I've cut some about 30" when needed.
Thanks! That was some great insight!Stob (n.) A small, straight piece of wood. Stake. Post.
You betcha! I’ve got lots of stob potential laying around my yard!Now all you need is a stob
