Removal of control board jumper
Caper1
24
Cape Breton
Would like to know what response will I or should I get when removing jumper from control board on a englander 25 ip ..should I have all controls working or would the stove even light .. trying to tack down a problem before I order a control board ...thanks
If you mean the thermostat jumper, the stove will light and go through startup, but then will only run on heat range 1 (if set for hi-low) or shut off (if set for on / off).
Eric
Reactions: Caper1
Eric
Thanks the thermostat will not work on the control board ..I started without the jumper and no wires connected to the control board and it lite and could kind of control the fuel and air but it did not shut down ..even with the jumper in I'm having problems with the controls ... I have another thread going and was help out ..great fourm
Reactions: ericofmaine
