How is this discouraging? It's normally not a complicated procedure but if one lacks the tools and mechanical skills then that's understandable. No new pipe would be needed.
It's hard to imagine this setup drafting well at 55-60º outside. The current stovepipe does not look dangerous.
Why was the work done in the first place? Was the old stove pipe in bad shape?
Was the chimney cleaned prior to the installation of the new stove pipe?
I like that idea, thanks. It's becoming apparent that I'm going to need to hire someone to do this properly.Honestly with that short of a rise i would consider swapping out to 2 45's instead of the 90. Might get a little more draft.
I like that idea, thanks. It's becoming apparent that I'm going to need to hire someone to do thiNo n
I wouodnt pay anyone to do this. but if you are not handy at all might be the right route.I like that idea, thanks. It's becoming apparent that I'm going to need to hire someone to do this properly.
I wouldn't say I'm not handy at all. I can measure, use a drill, etc. It turns out that I'm not able to find anyone local to do this for a reasonable price on a reasonable timeline, so I'd like to give this a try myself. How should I go about it? What safety issues should I be aware of?I wouodnt pay anyone to do this. but if you are not handy at all might be the right route.
This is not difficult to remove and replace connector pipe correctly.I wouldn't say I'm not handy at all. I can measure, use a drill, etc. It turns out that I'm not able to find anyone local to do this for a reasonable price on a reasonable timeline, so I'd like to give this a try myself. How should I go about it? What safety issues should I be aware of?
Thank you very much for these instructions. I guess I need to give this some thought. Seems a bit complicated. I don't have tin snips or a crimping tool.This is not difficult to remove and replace connector pipe correctly.
The open damper provides little to no resistance, and should not have an adverse affect when open. We don’t know if the damper plate is installed correctly on the rod you turn showing the handle position is coordinated with actual damper position. It could be partially closed and you don’t know it.
Tap the joints to break the seal created by cement. That is not necessary and should not be used.
The male, or crimped end faces down into the larger pipe below it so any condensing fluids from combustion stay inside and drip back down into stove.
Pipe joints are finished with 3 self tapping screws at each joint.
The only special tool other than tin snips to cut metal would be a hand pipe crimping tool that makes the wavy crimps on the male end you cut off. Do not cut the female end since that will be visible when put together.
Once pipes are removed, make sure the pipe inserted into chimney is not too far in. It can be slid in so far that it blocks the cross sectional diameter of flue causing the smoking issues.
The next thing when pipe is removed is to check the diameter of the chimney flue liner. This is critical to create the correct draft needed as well as fire safety possibly requiring an insulated stainless steel liner the same size as stove outlet. That is the most important part of the job.
Use a mirror to look up chimney flue assuring there are no obstructions. A certified sweep would at this point possibly recommended camera inspection if issues are found. They would also check exterior of chimney for clearance to combustible material.
It may have worked with the existing chimney, but over TIME may not be safe, and in the event of a chimney fire, the existing chimney without insulated liner cannot protect the dwelling from the intense creosote fueled chimney fire.
Exterior chimneys require 1 inch clearance to combustibles and interior chimneys require 2 inches. When these clearances are not met, an insulated liner is required.
As you can see, the black connector pipe is the simplest part of the venting system.
Not really, but the point is not the flow of gases. the crimp is toward the stove so that any condensed tars drip back into the stove and not down the sides of the pipe. There will be no horizontal section with a 45º offset instead.Could a reversed pipe in the horizontal section influence the flow of smoke and gasses?
They do have a small effect, even when open. Given the short rise to the thimble, I would leave it out.I know you don’t like dampers but I don’t think they affect draft when open.
Do you mean ONE 45-degree elbow, or TWO?There will be no horizontal section with a 45º offset instead.
Nothing wrong with getting a pro to do the job. I wouldn't hesitate to hire someone who will do the job properly and correctly first time out!I like that idea, thanks. It's becoming apparent that I'm going to need to hire someone to do this properly.
You have one 90 degree now. Two 45s equal 90.Do you mean ONE 45-degree elbow, or TWO?
Oh shoot, I didn't notice you said this. I should have read your instructions better. Also didn't notice the part about not cutting the female end. Well, live and learn. My stove is functional but not beautiful, what with silver screws and the cut female pipe. I did get the seams facing back and down, though.There will be no horizontal section with a 45º offset instead.
My CFM appears identical to the Englander 13.AFAIK, there is no relation between the CFM stoves and Englanders. The 13NC was purely Englander.
Visually yes though the door is different, but not sure internally? Maybe they contracted with Englander? What model CFM is this?My CFM appears identical to the Englander 13.
Yes, more rise off the stove would have helped. The 45s instead of 90s would compensate. The diagram I posted earlier is from SBI manuals.Does it look like the main cause of my draft problem is that the hole into the chimney is too low? Someone mentioned above that the minimum height to the vertical pipe is 3 feet.
Model #: 13 NC CLP. This manual came with the stove: https://www.manualslib.com/manual/186207/Cfm-Air-Tight-Wood-Stove.html#manualVisually yes though the door is different, but not sure internally? Maybe they contracted with Englander? What model CFM is this?
