Replace my Heat-N-Glo WSK-MLT Wall Control with a simple switch.
DukeCanBuildit
7
Kitchener, Canada
I have a Heat-N-Glo direct vent natural gas fireplace ESCAPE-36DV with the Heat-N-Glo WSK-MLT Multifunction Wall Switch.
The wall switch seems to be more trouble than convenience and the switch is only used to turn the flame on and off. I’m not using it to control the temperature in the room. The module seems to be stuck on “auto” and with a very low “set” point. It keeps cycling on and off intermittently, even though I’ve raised the set point to 90°F, and it’s getting a bit annoying. I suspect a new module is in order.
Rather than replace the WSK-MLT, I’d like to simply swap it out for a single-pole-single-throw wall switch.
I’m hoping someone can tell me which of the three wires should be wired into the replacement switch.
Many Thanks.
Edited to add photo.
[Hearth.com] Replace my Heat-N-Glo WSK-MLT Wall Control with a simple switch.
So yes it will work to swap that out with a single pole switch, but... You will lose flame height control. You are going to lose flame height control, lights if you have them, and blower control of you have them. So you are going to have to replace either the regulator on the valve or the complete valve, somehow rewire the lights or just eliminate them, and rewire and control the blower. This is not difficult if you know what you are doing
Reactions: DukeCanBuildit
Thanks,
My wife hates the backlight, so I pulled the bulb a while ago. There is no blower installed and I don’t care about controlling flame height.
The existing WSK-MLT default flame height is “Hi” when turned on. If I don’t change out the valve or regulator, would flame height simply remain at the default?
If so, then which of the three wires from the back of the wall control get wired to the single pole?
The more I look at this, the more I’m convinced I have to get rid of the black Control Box, the Flame Solenoid, as well as the Multifunction Wall Switch and wire the single pole directly to the IPI Module using only two of the existing wires.
So, would I leave the Flame Solenoid attached and just disconnect the wires or would it have to be removed and something put in its place?
I've done it with a new dexen Valve with manual flame adjustment knob
Make sure the fireplace doesn't have any type of split flow function (separate burner controls)before eliminating the electronic controls
Thanks,
It’s all very standard equipment except for all the stuff associated with the Multifunction Wall Switch.
It’s behaving like a faulty wall control but a partially clogged gas line could exhibit the same symptoms I’m experiencing. I’ll blow out the main gas line from the valve to the burner assembly and test things. If it solves the issue, I’ll leave things as they are.
If it does not, I’ll be stripping it down to a simplified unit that has an IPI pilot and a low voltage wall switch.
Thanks!
Thanks,
Thanks!
It would be a whole lot easier to test your pressure out test port first
Many Thanks.
I’ve ran into the same issue where the wall switch has gone bad and I want to replace it with a simple rocker switch. Did you eliminate the control module box and if so, could you please provide instructions on re-wiring? I believe I need the 060-521A. I have no lighting, no fan, no extra accessories. Just on and off. Hi and Lo. I want to keep the flame setting on lo because it doesn’t get too cold here in SoCal. Thank you
3v adapter, dexen board (you can probably use the one you have) dexen manual flame control valve, and wiring harness. The board says right on it where every wire goes.
Thank you for the helpful info. I’ll look into this. The replacement multi-function switch is over $100. My local heat n glo rep said I could purchase a WSK-21-W which is a basic on off switch, rocker type. It includes wiring instructions and the cost is about $35. So I’m going to look into this as well.
I use regular $2 wall switches and have never had a problem.
