Replacement chains
jcamp38
9
Michigan
How do I tell what size chain I need for my Stihl 291 chainsaw with a 20 inch bar? Also, does anyone have any good websites to order them from?
Thanks
[Hearth.com] Replacement chains
It is stamped on the bar....Ebay is your best bet for Stihl chain.In this example it is a 18 in bar with 3003 000 9417 being the bar reorder number...the 3/8ths stands for the chain pitch and the 66x is the amount of drive links followed by 63...the gauge.
I bought my last set of chains from Amazon for under $20 each. I went with Oregon LPX for my Stihl Farm Boss. I like the way that they cut and wear and I find them easier to sharpen on my grinder than the Stihl chains. You can lookup the chain type here.
When replacing a chain, match the following three specs:
PITCH
GAUGE
DL ( number of drive links)
As Tar12 mentioned, you may find this information stamped on a known compatible bar.
ASIDE: There is a fourth feature of a chain that sometimes comes into play with smaller saws. If your bar has a narrow kerf (NK), you have the option to use either a standard kerf chain or NK chain. If your bar is standard kerf, you can NOT use a NK chain on that bar. NK chains are found in .325 and 3/8LP pitches.
