Hello all,
I am faced with a garage door opener that is seemingly at the end of its natural life. When you push the remote button, the motor starts and turns, but the door doesn't open.
I've removed the casing to more closely inspect it, and my non-professional diagnosis is that the plastic gears that translate the torque from the motor to turn the chain drive sprocket are all stripped. (The many tiny plastic bits and shavings inside the casing is what tipped me off.)
I'd say the unit is maybe 10 years old - best guess. It's a Chamberlain 1/2 hp model.
It seems pretty straightforward; I'm considering replacing it myself - most likely with a comparable Chamberlain model - ut wanted to know if there are any pitfalls that I might need to concern myself about, or if this is a job that appears, on it surface, to be deceptively easy, but turns out to be lot more difficult.
Thanks in advance for all ideas, tips, hints, and warnings.
