I am looking over some things here and if I set up this pellet stove I have (Pelpro PP60-B) that will alleviate a lot of "stuff" I am trying to figure out how to work through.
The catch to it is the heat output of this is very low and the electrical requirement is a downer. So those are major considerations, more so the low heat output, in my scenario.
In working through considerations - a few questions:
1. I can't find a fuel consumption rate/burn rate spec. With the PP60-B running on max (continuous) - is there any realistic estimate of how much weight of pellets it goes through in some period of time (like 6hrs, 12hrs, 24hrs)? The heat output is up to 35k BTU and its spec'd at heating 1500sq ft, with an "EPA efficiency rating" at 79.4%, if that gives some indication of burn rate.
What I am needing to get down to is if we run this around the clock for a few weeks or a month when it gets real cold - how much fuel is it going to burn = how much weight of pellets should I have stored to get through? I am imagining buying in bulk - by the pallet possibly. It sounds like that might be 1-1.5 tons.
However, if I can buy in bulk at a lower quantity amount (say, 4-500lbs at a time) -
A. Will that get me enough fuel? and
B. What is the cost difference (if there is any)? If it is still a better buy to get a whole ton and is cost-effective to do so then that might be the way to go. I suppose the answer here lies in what is available locally, first.
2. I can't find a spec on vertical flue height. I can find specs on horizontal runs and angles, but I don't see much that pertains to vertical rise. The pipe I have is Selkirk 3vp, if it matters (3"). At this stage I don't have any reason to stay with Selkirk, per se, nor staying with 3", per se, other than it would let me use some of what I have, but I don't really have much to be a critical factor if there is "a better way".
What I would be looking at is about 14' of vertical and 4' of 45deg run with 2x 45deg angles. There would be no horizontal run, other than the port off the back of the PP60-B to a 45deg, slope run to another 45deg to the 14' vertical run. Would this be adequate? Would 4" be noticeably better than 3?
