Mybooman;
Is your chimney also exterior? 6 inch outlet on stove? 8 inch masonry or insulated prefab? Do the installation instructions require the pipe and chimney to be the same size as stove outlet?
All the principals apply to all stoves and the more efficient the design or smaller the firebox the more critical a larger flue becomes.
It's common to have a small stove and people think the stove won't heat enough so are looking for a larger stove when the problem is the chimney is so big the stove is having a problem heating it before it can heat the house. They think a larger chimney creates more draft so it should be fine. A larger flue is capable of more draft when more heat is left up it, but if you have an efficient stove with less heat loss it becomes much weaker than the correct size. Any stove benefits from not increasing the flue larger than the stove outlet.
![[Hearth.com] Reversed flue collar, creosote leak... [Hearth.com] Reversed flue collar, creosote leak...](https://www.hearth.com/talk/data/attachments/168/168630-fc8ae6921bb1f6898593d8e3e72fb573.jpg?hash=K9i_j0qVR2)
![[Hearth.com] Reversed flue collar, creosote leak... [Hearth.com] Reversed flue collar, creosote leak...](https://www.hearth.com/talk/data/attachments/168/168631-dc19e99e6e3ff0a1d0005d4590634301.jpg?hash=O-2HrfFOXl)
