You might be feeling the draft because a fan won't cool the air.My room feels cooler with the blower on high...Any one else experince this or is it just me????
Blower on high will cool stove off quicker than the blower on low resulting in a less efficient burn IMO.
That there is a loaded statement.lol
Blower on high will allow for more heat to be forced off the stove so that more heat can be transferred to the shell of the stove.
Question is will you ever with even the biggest blower cool the stove to a point that it actually effects the burn inside it.
Just remember the bigger the temp differential the more transfer.
Just stating what I observe. When I have the stove running nice and hot, I can maintain the stove top temp in the 600 degree range for a couple hours with the blower on low and then it slowly drops off over the burn cycle. If I do this with the blower on high, the stove top temp falls to 250 within a half hour of the blower on high. I would think running the fan on high throughout the burn cycle with the stove top temp at 250, you're blowing cooler air than at 600 degrees stove top.
Alas, with an insert you must run the blower.
Then again, maybe more heat is going up the stack.
I have noticed a direct correlation between running my blower on high and my secondary burn dying out much faster then if I ran my blower on a low setting. Resulting in overall lower temps because of incomplete combustion from the secondary burn tubes cooling off to fast.That there is a loaded statement.lol
about how close is your small fan to the stove? I'm generally 10 ft away from the stove.I have experienced a cooling effect as the warm air from the blower moves into cooler areas of my home. I aid this process by placing a small fan at ground level blowing toward the stove. This allows warm air to move into colder areas AND cooler air to move to stove. If you continue to burn your stove and run both fans the temperatures will raise across the home thru this convection process..takes a bit. I run both fans at a low speed
I keep my blower off. Reason being is shown in the pic on the right. I get the heat upstairs in my house better with the blower off. I figured this out 3 years ago then I saw these pics recently that showed me I wasnt crazy. LOL
First pic is with fan on and second pic is with fan off..
My small fan is nearly 60 ft from stove. Ranch style home.about how close is your small fan to the stove? I'm generally 10 ft away from the stove.
Would not have thought that would happen.I have noticed a direct correlation between running my blower on high and my secondary burn dying out much faster then if I ran my blower on a low setting. Resulting in overall lower temps because of incomplete combustion from the secondary burn tubes cooling off to fast.
