Is that wall behind the stove just stone veneer or solid stone? In any case, it will probably eat quite some heat. The dealer may overstate it a little bit but I would also say that with only 5 hours of burning you may just get the place warmed up enough that the oil burner turns off but you don't feel much difference. When you say 5 hours, is that just one quick fire or do you hold the stove above 500 F the entire time? Is there a reload involved? How much wood are you putting in?
Hi Grisu - Its a solid stone wall. It was above 500 the whole time. One reload. Probably about 6-8 logs total.
