A friend's house recently had a bad fire (electrical, not related to boiler). His father had installed an older Attack boiler system in basement, which was used infrequently in last 5 years. We were able to successfully remove the boiler from the basement. I plugged it in and the control panel came back on normally.
There was no fire damage directly to boiler. There was likely some water dripping down through the floor, and wet ash/debris on top of and in vicinity of the boiler.
What appears to be just an exterior housing (thin metal layer on outside?) was also slightly damaged in the move, and there is older rust around the bottom.
What should we look into further to determine if the boiler is still salvageable / capable of functioning properly, both due to the fire issues and the age?
I have the option of moving the boiler to my property and integrating it into my radiator system as a supplement. Would this be worth the effort with an older Attack?
Thank you in advance.
