Hello all,
I have had a Scandia woodstove that came with my current home that has been sitting in some unused room for my 15 years here that I recently rehabbed and moved into with the idea of closing off the rest of my house and winterizing it and "wintering" in these two rooms to save fuel oil that is well on its way to going thru the roof!
So its been many years since I've had a wood stove and I really like this Scandia and have been using it for about 2 months now but I saw another forum thread that kind of trashed it (from Taiwan it said- which for me is never a negative as my wife was made in Taiwan and she's top quality
and it also said they were hard to control and sometimes not safe. Here is a link to one that looks like mine
It vents thru the back with the wood going in the bottom chamber and that then vents up thru an opening in the top front of the bottom chamber and it then vents out thru the back of the top chamber. Seems like an efficient design as that top chamber allows a lot of heat to be "captured" and sent into the room instead of out the stack. On mine the air vents for control are what you see in the front of the stove and I find it very easy to control though I do sit with it with the door wide open to get a fire started but once going it is easy to throttle down and with 3 good sized logs in it I can easily get it to heat my 2 rooms for 6 or more hours (I recently rehabbed, insulated and have this place tight- to steal a contractor friends fave saying - " I can heat it with a match its so tight
. So..... that's my story but I'm of course concerned when I hear someone say they may not be safe. If anyone could comment on why they may not be safe and/or what I should watch for I would much appreciate it. Trying to save money I don't have but don't want to burn the place down of course.
Thanks much
Thanks much
