That is what mine looked like about a few hours ago The front of the stove was 650.
.....The flames, every so often, would jump off the top of the wood, and do a slow roll at the tubes....the wood was Maple, and Hickory at 16% on a fressh split....maybe 3 pieces (2 Hickory, 1 Maple) the size of the one off to the side. If I throttled it back a little more, it would momentum.
Well Oak isn't seasoned after 12 months, it takes 18-24 months for Oak. You won't see much secondary action with only one piece of wood either.The flames come from the wood past the tubes and past the baffle(they just go straight up) I put in 1peice in at a time once I have a good Amber of coals the wood is seasoned 9 12months and mostly use oak. What size diameter should I cut the logs
That's different than second base by the way.You won't see much secondary action with only one piece of wood either.
Yep wood needs friends at least 3.
I use to baby the stove to much but now if i need to just add 1 split to stay warm i would soon just let it go out and let my electric heat kick in.Haven't heard that one in a long time. Grandpa use to say that when he was loading the fireplace for the night.
Take that back! Right now!I use to baby the stove to much but now if i need to just add 1 split to stay warm i would soon just let it go out and let my electric heat kick in.
Yeah that come out wrong I just think a one split fire is not efficient as a loaded stove I hope that makes since.Take that back! Right now!
