Selkirk DT
canuck_22
259
Ontario, Canada
Hi all, I already have an 8 inch hole in the foundation, will that accommodate the Selkirk DT pipe?
Thanks
What kind of hole is the 8" hole? Out a foundation wall to the outside or an opening to a chimney? Either will work, but there are different installations for each.
Thanks for your reply, it is through the foundation wall, in other words the venting would be straight up and out. Would I need some kind of thimble or it would go right through and fill the void with some kind of sealing material?
[Hearth.com] Selkirk DT [Hearth.com] Selkirk DT Here is my set-up. I'm going thru a masonry chimney, but yours would be basically the same. I have to mix and match the different Selkirk venting to get what I need. If you call Selkirk they can help you.
