If you actually burn a full 20 cords, spend the value of 10 cords on insulation and you'll end up burning 4
Hi everyone,
I have had a crazy experience installing this woodstove. The "professional" installers I hired for a ton of money did a very bad job, not following code or instructions for the woodstove or chimney parts. They were Blaze King dealers and had been in the business 18 years and I was shocked at all that was done incorrectly. I had to educate myself on how to install everything, and I am pleased with everything except one thing. The woodstove is in the living room on the main floor. It goes through the ceiling, then through a knee-wall attic and up through the roof. I built a box in the living room ceiling/floor of the attic and 2 of the sides give a 2 inch clearance from the packed pipe but I realized the other 2 sides would only give 1 7/8 inch clearance after I built my box. But after I re-plastered the ceiling, screwed in the chimney support, and installed the chimney, I measured and one of those 2 sides is 2 inches and the other side is 1 3/4 inch clearance. So both 1/8 inches landed on the same side of the chimney. So my question is is this dangerous? Do they just say 2 inches to be safe but it's really less? If so, how much less? I'm a little stressed about it because the box is set, the 17 ft of chimney is up, the ceiling is plastered, and roof brace kit is in place, etc, etc. The 1 3/4 inches is the only part of the whole installation that does not have proper clearance. What say you?
It's not right and you know it.
It might not be perfect but some common sense is important here too.
I disagree. True, there are exceptions as there are to any rules, but most try to follow code or exceed it. Many folks come here because they have a problem. The normal and easy installs usually do not need assistance.I hate going against code...but around here EVERYONE does. I would recommend trying to fix it properly...
But if you don't fix it, maybe stuff from Roxul or some other fire resistant/fireproof insulation in the gap? Just tossing out ideas.
Andrew
I love my Fein! Best tool ever for trim, moldings etc! You can get the Craftsman version to save some $$$, especially if you only use it occasionally. Good suggestion.I'll start by saying I DONT know enough about your specific problem to give advice. On the other hand im a carpenter and I deal with cutting holes in every type of material imaginable and reworking a lot of things to how I want them.
Trust me you can surgerize this situation and really not make much of a mess. I know you like surgerize, it's a great word.
My guess is you are thinking that you'll completely remove the offending framing and move it, in turn damaging the plaster and lathe that is surely attached to it. Am I correct?
If you've got access from above a fein multi-tool or equivalent vibrating trim saw can remove alot more material than you think. If you plunged straight down and essentially shaved a half inch off the wood you'd be golden. Plus this type of tool does not bounce the framing like a sawzall would and shouldnt cause any damage to your plaster.
You can do it just be slick about it.
....Be it a gfci breaker for a bedroom ($80 or more..most just buy a 20$ 15 amp one) ...
Of course they don't use GCFI breakers......the national building code calls for AFCI breakers for all sleeping areas [emoji6]
Just nitpicking [emoji2]
Leave my mother out of it. Hell, she just discovered texting! You think I would want her to have a wood stove in Los Angeles!! Good job...close the thread.I guess you're right. I've never seen it. Too new to burning. But once again, I am just saying, that there are likely lots of people who don't follow code for multiple reasons and who shouldn't!!
And as people who are very knowledgeable in your own fields, you are unlikely to see install issues within your circle of friends/family. An example: I am in law enforcement. Guess what: nobody in my circle of friends / family have criminal records or are in jail at the moment pending trial. So I'd doubt that BKVPs mother's stove is not installed to code. And everyone, not just industry employees, must preach following codes. But from someone who lives in an area that is fairly isolated, and where EPA stoves are a new concept and as is seasoning wood, the majority of the installs I have seen don't follow code whatsoever. Hell, 75% of the people here cut their wood in the FALL and burn 2-3 weeks later.
On another note, the OP will fix the problem and have a clear conscience and code will be followed.
A
12 eco bricks in the woodstove
