I run a Buck 81. It is not a catalytic stove and burn times aren't particularly long. However, the 91 is and has a large capacity fire box with much longer burn timesAnyone have any experience with the Buck 81 or 91 inserts?
My Kuma does run low, but not BK low.Sounds like the only options I have for what I am looking for would be a BK Princess or the Buck 91.
Can any of the hybrids run slow and low?
The fire box size difference is notable between the two.But the princess won't have an 8" flue, so if you want that, it's the buck
Would love to do this, but it would take up too much room if I did. The fireplace has a hearth that sticks out about 15", and is around a foot off the floor.@Gearhead660 I wanted to throw this out there, have you looked at the rear vent freestanding stoves from woodstock and jotul? Put it in front of your fireplace and get long slow burns from the woodstock. If your fireplace is big enough to fit a Buck 91 then you "should" be able to put a rear vent freestanding in front of the fireplace.
Congratulations. That's a great find!So, came across a great deal on a PE Super Insert. In very good shape, looks to have only had a handful of fires. 2010 model. Will be going through it and plan to have it installed for this fall.
Looks SuperAll checked over, cleaned up, blower motors lubed, and a fresh coat of metallic black Stove Bright paint.
Plan to during heating season. Like to put it in during warm months, looks nicer.Leave it open, it will heat better.
