Hi Everyone. I have a somewhat unique set up in my house. I have an oil burner as my primary heat (baseboard water) which also heats my hot water with a separate reserve tank. Nothing too crazy about that. However, I also have an electric water heater. The prior owner installed it because he didn't want to burn oil in the summer. So you can switch between which system you want to run at any point.
The theory is that oil is more efficient if you are already burning oil to heat the house but not when using the boiler just to heat the water. The oil burner is not high efficiency - probably around 15 years old.
The old owner didn't burn wood for heat. I'll burn on nights and weekends. Basically if we are home we burn.
If the stove prevents the oil heat from coming on or coming on as much then I think it's like running the oil in the summer for the hot water.
I'm curious what you think would be a good way to think about which is better. I'd like to save money but also interested in the option that's better for the environment. How would you try to figure out which way to go?
. It's hard for a homeowner to make fine tuned efficiency decisions since there's so many variables we can't measure ourselves.
