I have an enviro Venice 1200 wood insert, once it is burning good and hot and the secondaries are roaring, there is an odd smell coming from the chimney. I am very new at wood stove burning. there is no smoke coming out, just a good heat wave!
Sounds like it's still burning off. Paint and sealants need time to cure and burn off on new heating appliances
Sounds like it's still burning off. Paint and sealants need time to cure and burn off on new heating appliances[/QUOTE
The fire looks fully engaged, much like that in my avatar pic. To reduce large wood gas blooms burn down the coals before reloading. To burn them down I put on a couple small 1-2" branches on top of the coals and open up the air at least 50%.In that picture the air has been closed completely for almost an hour, I don't know how to control the fire other than the air I am up though for any suggestions
I get this too. The smell is reminiscent of creosote but different, more chemical as you describe it. If I went outside now I'm pretty sure I'd be able to smell it because with the stove top temp reading 635 degrees, the secondaries are really rolling.With my stove I can often tell that the secondaries are going strong even without looking up at the chimney (which typically has little to no smoke) as there is a distinct chemical-like smell . . .
ENVIRO,The smell kind of reminds me of when an oven is put on the self clean cycle and it gets extremely hot.
It's once the secondaries are burning very well
Does that bolt unscrew easily ?
