Ever use pine cones for firestarters? they work nice, the more sap on the outside the better, just remember to use gloves when handling, and use them once they turn brown, (depends on the veriety).
Beetle-Kill said:Consider yourself lucky, you mention Ash or oak around here and people start talking furniture. BTW, I've never swung a stunted cat, but that sounds like something I need to add to my "bucket list". is it a good time? ;-P
Wet on the surface won't result in popping, at least not with hardwoods. Can't really imagine a mechanism for it to do so with softwoods, either. It really is just on the surface and dries up in minutes in the stove, so won't be lingering around in coals. I would suggest, though, bringing in snowy or water-wet wood to the house a day before you need to use it so it dries out before you throw it in the stove.
Jutt77 said:Wet on the surface won't result in popping, at least not with hardwoods. Can't really imagine a mechanism for it to do so with softwoods, either. It really is just on the surface and dries up in minutes in the stove, so won't be lingering around in coals. I would suggest, though, bringing in snowy or water-wet wood to the house a day before you need to use it so it dries out before you throw it in the stove.
I think that softwoods like pine pop quite a bit is because softwoods are not nearly as dense as hardwood. Less density equates to a wood with more air pockets. As the air pockets heat up, the air within the pocket expands until in explodes under pressure. So more air pockets mean more snap, crackle, pop!
BeGreen said:Actually I think it is the pitch and moisture pockets that create the popping. The power of steam is a mighty thing.
BeGreen said:Whoa, some pipes in that system are close to 100 yrs old.
Jags said:She IS the wife, Soupy. :lol:soupy1957 said:+1 on the Bag Balm, if you can get your wife to stand the smell!!
soupy1957 said:...........then again, (being raised in farm country), ...........I LOVE the smell of the fields after they have been turned over, and fertilized, in the Spring!!
-Soupy1957
I could skip the smell of manure being spread on the fields . . .
