Cat stove myths:
- They take too much effort.
- You can't see a fire.
- You have to replace the cat every two or three years and it is expensive.
Non-cat myths:
- You have to burn them really hot or they crud up your chimney and smoke. (Only if you burn wet wood like the stuff that will plug up a cat in a heartbeat)
- There has to be flame blasting out of the secondary air outlets. (Only if you live to post videos on hearth.com of you wasting wood and heat.)
- You can't burn clean in them at lower stove top temps.
- They give you acne.
Non-cat myths:
I really thought I would miss the fire from a tube stove, I haven't missed it in the least, I usually load the stove burn it hot for 10-15 minutes and then turn it down to the point where the flames get lazy and let it burn until I decide to turn it down for the night.
