Solar kiln temps
Newt243
73
Arkansas
How long do you think to get this dead standing post oak to acceptable moisture content? It was around 28-29% when I split it.
[Hearth.com] Solar kiln temps [Hearth.com] Solar kiln temps
What stove is the wood going in?
The only way you’ll know is to pull a piece at the end of September, split it, and measure it.
I'd like to see some blowers moving the air through
Too much airflow will cool it down. I think OP has the right idea with just enough vents to let the moisture out. Personally I would've wrapped the plastic all the way down with just an inch or 2 open at the bottom.
The bottom couple rows have actually been seasoning for a year and the moisture was below 10% on a couple pieces I check so I wasn’t worried about them not being wrapped. I think a fan might be helpful on green wood but with this tree already being dead it wasn’t holding as much moisture. This is my second year doing a kiln so I’ll see how it goes. For some reason I didn’t cut near as much wood this winter as I usually do so I’m behind!
Reactions: GG Woody
Yes, I think a blower would help move the humid air out of the plastic tent. If you can see water droplets on the inside of the plastic, that means the water condensed and did not come out. If you wrap it all up but install a chimney pipe roof flashing on the side you can terminate the plastic there and mount the blower. Even better would be a blower on each end. It would suck air from the bottom and move it out. Even if the blower was not running, or not there due to rain, there would still be ventilation.
You need to circulate that air inside not vent it out. I bet I’d measure the temperature at the center of the stack it’s much much lower.
Shooting with a temp gun through the openings and the temp only varied around 5 degrees or so even to the middle of the stack. It was a little cooler on the North facing side but still in the mid 130s. I’ll probably pull a piece out in a few weeks and split it and check the moisture level.
Reactions: GG Woody and EbS-P
Some solar kilns work, some don't. I'd read up on the solar kiln shown here by our member who has a good proven design.
Can someone help with finding the kiln instructions thread. I'm spacing on it and a solor kiln search is not pulling it up,
How about this?
Yes thanks, Woodsplitteru67 has his build instructions posted here.
Reactions: Whitenuckler
The kiln looks ok except the bottom portion. Don't do a blower, leave it alone. The temperature inside the kiln is good and I read that it is vented. Me personally I would have started it a little earlier. I did my kiln the week after the 4th of july this year. Keep the kiln together through October if you can and your wood should be plenty dry.
