New guy here and I have spent probably 14 hours over the last few days reading old posts (as if you haven't heard that before!) I will be putting in a stove this fall (new addition) in Norther Wisconsin and started looking around for a good looking stove that has it all. It doesn't exist! I was real excited about the Lopi Cape Cod as I think it is gorgeous. The Jotul line has some impressive stuff too. After reading much written about the Cape Cod and it's problems, I've basically written it off. I then started getting into the PE Alderlea T6 as an option. Doing my research on that, I was intrigued by what I was reading about the long burns on the BK Ashford 30. (A real BIG thanks goes out to "webby365" for all his posts!)
Like I said, not every stove is going to have it all - I realize that. I have a question about the Ashford yet. (Forgive the "rookie" questions here but that is exactly what I am!) I know the CAT is designed for long slow burns. On a fall evening with the windows in the house open (and grandchildren gathered around), I would like to have a "show fire." Would this be possible by just running the stove and leaving the bypass open? Obviously, I'm not trying to heat the place but know I will get some from a hot fire. I'm just wondering if the stove is also designed to run this way or if I would be doing any long term harm to the stove. (Yes, I know it won't be as efficient in use of wood, will throw more emissions up the chimney)
Thanks in advance
Thanks in advance
