Hi all,
Looking to get a sooteater setup. I have a Enviro Boston 1700 in my fireplace with an insulated liner. Run is about 33-34'. The run is pretty much straight up. slight curve from where I had to cut the damper and fit the liner through. Should I get the white rod kit or black? I read the white is more flexible - but is that needed for me? I have no 45 or 90 degree bends? Plan on going from the bottom - no roof access - too tall off the roof and no way I am doing a ladder on that pitch!
I ordered a SLK-24 kit from Tractor Supply for $99 (with the white rods) and 2 extension kits, but I was not paying attention and the extension kits are for the pellet version and not compatible.
So I can order 2 black rod kits (6' each) to get me to 36' for another $55. Or return it and get the 36' all white kit off amazon for $163.
Price is comparable - so not sweating that - but wondering if having some of the stiffer black rods would be better for my long run. (did I seriously just type that?!?!)
Thanks,
Joe
(ignore the antenna (long gone) and red line - old pic but gives you the idea
Thanks,
Joe
