Speeco wedge's gone kaput
HeatsTwice
592
Santa Rosa, California
I bought this splitter for $435 and all my neighbors bought a share for $100 plus long term maintenance so it's seen a lot of use - at least 40 cords split by all over the past 5 years. Been through two cylinders so far but everything else has held up well.
But as one of the neighbors was splitting up some Eucalyptus the wedge finally gave out. I'm looking for a new one from Speeco but no luck yet. Will probably have one custom made by local machine shop. I wish I knew how to weld. It doesn't see like it would be hard to make one.
[Hearth.com] Speeco wedge's gone kaput [Hearth.com] Speeco wedge's gone kaput [Hearth.com] Speeco wedge's gone kaput [Hearth.com] Speeco wedge's gone kaput [Hearth.com] Speeco wedge's gone kaput
That wedge looks like it's seen pretty tough use and maybe something other than wood logs. It seems odd you can't find a replacement. Someone will chime in here I'm sure.
Reactions: TreePointer
The reason why it may look like it was used for something other than splitting is that I had to use a sledge hammer on the knife edge just to get it off the splitter rail.
I sent an email with pictures over to Kevin in the Speeco engineering department. Just no reply yet. I think this splitter is pretty old.
I wonder if someone installed a GRADE 8 bolt instead of GRADE 5?
These splitters are designed such that bolt is supposed to shear before the wedge or any other part is damaged.
The bolt actually looks too small, loose in the hydraulic ram, and the hole is all egged out on the wedge. 40 cords, 5 years is really light use, my opinion. Two rams you've been through?
It can be rebuilt, better than new, we have the technology. Any local fab shop can repair for you. Best to find some small outfit. Might check the local craiglist in your area in the services section.
Well, like I said, I bought the splitter used. Who knows what it had been through before then. The cylinder it came with sprung a pin hole leak, soon after I bought it. Its been great over all. But its so old that when I try to get parts at Tractor Supply, they just roll their eyes.
If you look at this manual there's a parts breakdown. Does the wedge look like yours?
(broken link removed to http://www.farmexinc.com/whitepapers/S401622BL%20Manual_Revised_2012.pdf)
Yes, thanks, this looks a lot like mine although it has more modern features.
btw, the serial number plate shown on page 14 of that splitter is not on mine. Nor can I find the model number. Can't seem to find them anywhere - even checked the bottom of the I beam.
Btw, I like a challenge also. Its nice to get dirty with machines like this on the weekend after a week as a computer jockey.
Reactions: WiscWoody
If you go to that farmexinc site there are other Speeco splitters that look like yours. You can look at there manuals and maybe find an exact match. Good luck!
I don't believe the bolt is what is taking the pressure during the "push" phase. I think it is there for the "retract". That bolt (even the enlarged hole) is WAY too small to take that kind of pressure. I use 1-1/4 pins.
Even if you have to have custom work, it shouldn't really be a big project. I could have that fixed in an hour or two.
Reactions: aussiedog3
That does make sense.
They do want something stronger than GR2 in there. My manual specifies GR5. Retracting with a stuck log can get troublesome.
Amazing display of abuse!
Goes to show why one shouldn't share tools with others.
I have a Huskee splitter that had a wedge collapse, no where near as bad as yours and Speeco replaced it under warranty. They told me they had a batch that was not reinforced internally the way they should have been. To me it looks like yours was missing something inside also but since you bought used you are on your own. They should be able to sell you a replacement though.
Really though, after it started to collapse or come apart, how long did you keep using it?
Amazing display of abuse!Goes to show why one shouldn't share tools with others.
Sure the guy that borrowed it is a bit of a duffis but every time it breaks, he throws money at me until I fix it. So what the hey.
I didn't Mr. Duffis did. I came home a week later and he showed it to me.
Another neighbor was the one who put the wrong size bolt in. But the wedge was failing long before the new bolt. Like JoeyD indicates the wedge had a hollow center and thats what failed.
So Mr. Duffis has been renting another splitter while mine is out. I took a picture of the wedge on the one he had (below) and will have a machine shop build a new one like it ($300)
Btw, I called Speeco and was told that they no longer make that wedge and do not have any in stock. Their advise was to buy a new splitter. But for $1500 I am going to take a chance on building a new wedge. The splitter is in pretty good shape otherwise. 8 HP honda, new cylinder, good pump and hoses. It still has some life left in it.
I will post pictures of the new wedge once I get it.
I would build it differently (i.e. less expensively). What I would do, is instead of milling down a 3x3 section of bar stock... is make the blade out of inch material, flame cut it, grind it, mill it (whatever) to a point. put the socket on the back of the blade, drill the hole so the ram hits the back of the blade fully. use the bolt to retract the blade only finally, weld on a 2X3 angle on either side as spreaders. while my spillter's cylinder has a yoke on both ends, this is the basic configuration of the splitter blade. it hasn't failed in 40 years or so....
Any pictures of your wedge? I could pass it on to the machinists to get the assembly more clear. Great idea.
here ya go....
your ram will not, under any circumstance, crush the 1" blade configured this way.
Reactions: HeatsTwice
Yes the ram should have been pushing on what was once a flat plate on the backside of the wedge.
Just weld a new wedge onto it that you buy or custom make
