Alright, I ran into an issue today with my splitter. I could only build pressure up to about 700 psi while splitting some tough locust wood. I have my relief set at 1500psi and if I cycle the cylinder to the end, my gauge will climb right up to 1500psi, however on a piece of wood it just tops out at about 700. I believe the pump is not going into second stage. Howcan I determine the exact issue, whether it be a pump, cylinder, or valve problem? All 3 parts are likely 20+ years old. Let’s see if you folks can help me narrow this down. Thanks in advance.
