kenora said:I've got a 5 ton electric and sometimes when I can't push through a piece of wood it'll get stuck on the knife. In my case the hydraulic arm is pushed and the knife is fixed; I think thats best since if you need to "beat on the piece of wood" to get it off the knife I would rather it NOT BE ON THE HYDRAULIC SHAFT, that would likely damage it. fwiw.
••RICKS. Horizontal makes sense to me, as I can lift it from ground ht to 9'. I plan on sticking it over a trailer and letting the splits drop; that shelf would be a good idea, though, if I want to get organized and stack stuff. I am going to have some kind of low log cradle, too, so I don't have to have my hand on the wood to steady it as it splits. I went brain dead once and lowered an outboard onto my thumb (neoprene glove, cold water; thumb could not tell where it was), splitting the nail and underlying bone. Sort of hurt. I'd hate to have a wayward finger between a log and a knife w/ 17 tons behind it. Your splitter must have some serious force to split 4' oak. We have nothing like oak up here, so I am thinking of a 4-blade knife to nuke everything at once. Thanks for the info. johnricks" date=" said:jklingel,
Since you have a loader for lifting and pto power, wouldn't it make sense to build a horizontal splitter of good height to save your back and powerful enough so it won't get stuck in the wood? I think with a vertical, the wood is at ground level, which doesn't require lifting, but you'd be bent over all of the time.
To respond to your original question about pushing wood or knife: I've never built a splitter, but I have one that does four foot wood, that I have modified. It pushes the wood to the knife. I built steel carriages or shelves on each side to catch the splits so they won't drop to the ground and to provide a work surface to lay halves aside while re-splitting the other half. It works super. Never bend over and never lift. BUT, because it is a "push the wood" design, the shelves are carriages because they carry the unfinished pieces back and forth as the cylinder cycles and it took some head scratchin' (for me anyway) to build the shelves so they could ride back and forth, not bind or get in the way and hold the weight of green four foot oak. If you build your splitter with a "push the knife" design, since the wood doesn't move anywhere, all you'd have to do is weld a couple of stationary solid shelves of the right size and strength directly off of the I-beam. Just a thought.
Rick
wildbillx8 said:My white, which is an mtd, has a wood dislodger down by the retracted wedge in case that problem occures. if you go on their website you can see their designfor an idea or two.
Gooserider" date=" said:I'm not a big fan of multi-way wedges, ...and I'm also much fonder of an H/V machine than I am of a vertical only...
However I don't see how the end you put the wedge on really changes the minimum beam length, or the length of the machine,
Gooserider
Smokey said:My splitter goes H/vert and I prefer horz. Mine has arms that catch the splits, so they normally don't fall on your feet. My understanding is the wedge on the ram produces more torque on it. My ram has play in it, maybe keeps you from bending it. I also can use mine verticle with the fixed wedge on end without problems. Maybe it's personal preference, but most of the commercial units push the wood to the wedge, maybe there's a reason for it?
jklingel said:I am interested in the 4-way wedge because I don't want to handle wood more than necessary. If some pieces are large and some small, so be it. I am fiddling w/ a simple (may not exist) way to keep the wedge centered on the wood, just for the sake of uniformity.... sort of. Good splittin'. jGooserider" date=" said:I'm not a big fan of multi-way wedges, ...and I'm also much fonder of an H/V machine than I am of a vertical only...
Gooserider
jklingel said:Wood: Thanks. I'll look them up, too. Lifting the wedge is a simple solution to centering. The Brutes sound a bit like these http://www.timberwolfcorp.com/log_splitters/
Check out there TW-10.
jklingel said:Wood: The TW-5 shows pics w/ the cylinder lifting the wedge; pretty slick. How long are the pieces you are splitting that are 2-4' in diameter? And, are you using a 6-way on them? With which splitter? I am curious about your tonnage (force) for wood that size; we don't have anything near that big, so I am wondering if a 5" cylinder is 2 tads of over-kill for me. Over-kill is usually good, though; if the parts don't cost much more, then go over-kill, in my book. Weight will not be an issue.
With the LaFont, all 5 fins on the wedge hit the log at the same, and even with 27Tons or more, it quite often was too much for the machine.We use essential cookies to make this site work, and optional cookies to enhance your experience.
