st croix afton bay pre 2003 switch idenifcation
Nov 6, 2016
119
Wisconsin
Okay I took a photo of my afton bay pellet stove, 2002 year. What is the 3 wire switch? The one on the cumbustion fan is the proof of fire switch low limit. So i am guessing the other with 2 wires is the high limit? There is another that sits under the low limit. Can you identifiy these switches for me. I am learning. Most of the switches ohm out at 0 with the stove cold and off. Thank you in advance.
You might get a better response if you posted in the pellet section. By the looks of your picture isn't that a wiring diagram under the bottom switch?
Ya thanks for help? I realized i posted in the wrong category after i posted, trying to remove it. Ya you know i noticed that wiring digram myself! But it tells you nothing. If you don't have any comment of info, and only mr know it all talk to me like i am stupid then don't comment.
Hi Mikey on pages 24-27 is the parts breakdown you should be able to match part numbers to the switches you have on your stove
here is your manual (broken link removed to http://stcroixstoves.com/pdf/Afton-Bay-Manuals.pdf)df
Another (broken link removed to http://stcroixstoves.com/pdf/installation/Afton-Bay.pdf)
