I don't get on here and post but I do read a lot of threads and take notes. This is a pic of my two 500 gallon propane tanks I'm stacking.
any thoughts on cutting them in half like this?
I wouldn't give up yet, just get a opinion/solution from some one that is qualified. Depending of the dia of the circle you need, I would guess, repeat guess that the 1" you were thinking of would be plenty. I would think that this would also require pre-heating the heavy plate prior to welding to the maybe 1/4" wall tank. You might ask over at; http://weldingweb.com/forumdisplay.php?10-Welding-Projects-amp-PicturesThanks for all the help
Im 5 minutes from that Santa
On another note, can a person buy the dome ends?
this would allow me to make 4 tanks for vertical installation
These tanks are non-pressurized, correct?I think I went pretty far, with my tanks. If I did it again, i'd do flat bottoms.
I am interested in the size and thivkness of the plat used for your tanks.I checked with my guy and he says the plates are reinforced with channel iron on the bottom . He also tests to 35 psi before the tanks are shipped. I usually run at around 20-22 psi max. Sorry, I forgot to ask how thick the plate was.
This type of construction will not be able to hold 5 psi, unless there are some stays inside to keep it "flat"
What made you decide to cutt tank and invert domeote="kjahnz, post: 1967571, member: 23979"]I think I went pretty far, with my tanks. If I did it again, i'd do flat bottoms.
