Yesterday, I fired the Ashford back up. It was rainy and cold and the forecast called for continued rain through Tuesday.
Since I was really tired, I decided to light off with the Blaze King fire starter that came with the stove. It went off fine but the smoke wasn't venting up the pipe but rather curling back into the stove. Then the smoke started coming into the house. I'm not sure from where. Does the stove itself leak when it's not drafting?
A few minutes later, it began coming out of the place in the chimney pipe where the two sections are screwed together. The top pipe sits over the lower pipe but, since the smoke was descending, it was spilling out through the tiny space between the pipes. Again, is this normal?
Obviously the problem was my inexperience starting fires. I opened the windows and set up a big fan to drive the smoke out, then opened the door to the stove and began blowing onto the fire. The air began rising up the stove pipe. I then left the door cracked for 30 seconds and everything was fine after that.
My concern is just whether the stove and pipe should be absolutely tight always or if it's normal to get some smoke leakage under these circumstances.
Also, how can one order more of the Blaze King fire starters? Is it alright to use other fire starters?
Is it alright to use another brand, such as Lightening Nuggets, which are made with "recycled forest by-products" and paraffin wax.
), crack open a nearby window, and place a large sheet of newspaper barely crumpled on top of the fire. Light your fire then immediately light the newspaper (or vice versa). The quick blast of heat from the newspaper usually jump starts the draft.
