Stove Bright dry time??
Hiram Maxim
1,065
SE Michigan
So to match my new re-model I painted my Englander 30 Metallic Brown!
(broken image removed)
How long do I let the paint dry before I do my 2 outside small fire paint cures????
Thank you,Hiram :cheese:
Brown! You da man! Woods stoves should all be brown just like God intended them to be.
I did the 30-NC in five coats of Stove Bright letting each coat dry for fifteen minutes or so. Them I rolled it out of the garage the next day 12 or 13 hours later and lit it off it off and straight up to 550 degees and everything went just fine. One thing I did that you may not have done is I burned in the factory paint before I painted over it. Don't know if it will make a difference but I wanted the manufacturing oils in the steel cooked off first.
Edit: Never mind the curing. I thought you had painted the 13-NC. That 30 of yours is for sure pre-cured enough before the paint job.
Bart,
Who do you think I got the idea from? :roll:
My Dad's "Country Comfort" is that Metallic Brown and I have always liked it!
I sanded most of the factory paint off.
I have 3 coats on it right now (got dark out) and will use the rest of the second can. I waited about an hour in between coats.
Guess I will do my curing burn on Sunday evening.
PS: My 13 is going to my best friends house. He helped me remodel my house and he needs it way more than I do! Maybe a Fireview or a Blaze King in the future????
With all the insulation I put in my house I may not need it anyway ;-P
Cheers, Hiram
Edit: what color did you use?
I used Goldenfire Brown the original paint on my old Sierra insert. Turns out it is what Harman uses too.
BB can you post a pic or a link to an existing thread when you get a chance.
I would like to see your stove.
Thanks Brother...
Thanks Brother...
I post this one more time Craig is gonna start charging me for disk space.
The old and the new.
  • [Hearth.com] Stove Bright dry time??
Brown is good. Goldenfire Brown is best and would have been god's choice. It blends well with almost any decor. That has been the color of my stoves (except my current green porcelin) and stope pipe since I began burning 20-25 years ago.
BB,
I did however paint my door....
The 2 tone looks pretty damn cool though!
