What do you recommend as far as how hot the stove should be ? Is over 500 f too hot and should I put a kettle of water on top of the stove to add some moisture
Ok that's good to know. It's my first year burning and the stove top thermometer said 500 I broke it in as per the instructions. How accurate are the thermometersYour stove top surface temp on the top of the stove can get hotter than that with no issues. My stove can cruise at 600 - 650 easy , I have had it up to 750 using an Infrared hand held thermo which is pretty accurate. My spring thermo's are not always that accurate but they are old.
Ok thanks will doMax temps depend on the stove to a large extent. Cast iron and soapstone types need to be run a might more conservatively. Check with Jotul on max temp recommendation.
Thank you BGVaries, some times a lot. You are doing fine at 500F. When it gets colder you may be pushing for more like 650F.
To be a little clearer on this, free standing stove top temps really depend upon your stove.Your stove top surface temp on the top of the stove can get hotter than that with no issues. My stove can cruise at 600 - 650 easy , I have had it up to 750 using an Infrared hand held thermo which is pretty accurate. My spring thermo's are not always that accurate but they are old.
I'm looking for a kettle for our stove, but mostly for a splash of color and looks. The small amount of water evaporation from one is negligible for humidification. If low humidity is a real problem you would need a proper humidifier. Or put a Bowflex in the room and start sweating!Depends on your house. My house is moist. I don't try to "add" moisture to the air at all.
Lmao maybe some bowsex instead to lose some calories oh yeahI'm looking for a kettle for our stove, but mostly for a splash of color and looks. The small amount of water evaporation from one is negligible for humidification. If low humidity is a real problem you would need a proper humidifier. Or put a Bowflex in the room and start sweating!
They are all mostly about the same. I have several and compare. When they all read the same, I figure they are fairly accurate. It is really too bad nobody makes a really quality one, that of course costs more, but it is a relative thing anyway. I just correlate what the stove is doing to what the thermo says and go from there. For a lot of years, I had no thermo and just went by my instincts. Still do I guess. The thermo is just kind of a novelty for me. When the stove is too HOT I know it.The thermometer I got is a inferno, is that any good , however , I did order the gun to be on the safe side.
The Inferno is the Condar. Well liked. I have that also and am still awaiting my IR gun. I like knowing the temp of my stovetop because It's still new to me. I imagine after a while you need it less, but I do think some kind of high temp alarm is a good idea for anybody.The thermometer I got is a inferno, is that any good , however , I did order the gun to be on the safe side.
Once we get burning 24/7 we run the humidifier, our highest stove top temp we can run at is 800, we usually burn between 600-700 in the dead of winter. Our pipe temp will run between 450-500 to start with. Check your manual for the temps you should burn at.What do you recommend as far as how hot the stove should be ? Is over 500 f too hot and should I put a kettle of water on top of the stove to add some moisture
the inferno is made by condar - a good company. I have two - placed them on either side of my new stove to make sure both sides burning equally as hot and no gasket leaks. Both read about the same except at cold start when one side may have more flame than the other.The thermometer I got is a inferno, is that any good , however , I did order the gun to be on the safe side.
We can easily hit 700F on our Rangely and it handles it fine. I try to run around 600 as that is just about right in the dead of winter for us.
Pete[/quote thanks Pete
Thank u that's good to knowthe inferno is made by condar - a good company. I have two - placed them on either side of my new stove to make sure both sides burning equally as hot and no gasket leaks. Both read about the same except at cold start when one side may have more flame than the other.
