Successful test
ispinwool
386
Butler County, Pa.
Quite awhile ago I'd mentioned that I was going to whip up "window quilts" to see if they'd make a difference in the temperature of our porch.
It's currently -4° outside with the wind chill and we're comfy sitting here at roughly 68°-70°.
I think I like how they turned out
[Hearth.com] Successful test [Hearth.com] Successful test
We have four sliding glass doors on the south side of the house that let out a ton of heat. We use insulated drapes and they work great, unbelievably so. I imagine quilts would be even better. What kind of batting are you using?
Reactions: ispinwool
It's the stuff folks use to make potholders...it's waffle-ly on one side and reflective on the other.
These are just prototypes. Now that I like how they work I'll have to come up with ways to improve them.
Did you get tired before you were able to saw all the way through the table? ;)
Reactions: SpaceBus
LOL
Hubby sawed through the pvc pipe I used to hold up the quilts. That poor old table has served as 'eating area' 'sewing area' 'workbench'...just about everything!
That's a great idea to make your own! I wish I was that crafty. We have them on all of the double pane windows in our house and they're incredible. But they're also incredibly expensive....
I use the commercial double cellular blinds on my windows with side seals. They make a big difference in very cold weather. I can set right in front of window and not get any cold drafts or chills from radiant heat heading out the windows. They are not cheap but take up a lot less space when up than a quilt. I don't think I ever would payback my blinds strictly on BTUs savings but a major improvement in comfort.
Great idea! Do you know what the material is called? Or may I ask where you purchased it from?
i'm curious to know more about the materials you use to make these - i think my house could really benefit from some. i keep the blinds down in some of the rooms for similar reasons, but making curtains especially for retaining the heat and blocking drafts would be something i'd invest time in!
It's "fess-up" time....when negative wind chills are expected, one must hurry to get things buttoned up. Lol
This is the window I didn't have time to do correctly.
It's the windward side of the porch so I wanted it covered.
I got the quilty stuff at JoAnn fabric. I had to order online since our local store doesn't carry it.
Be sure to sign up for coupons before you have to pay full price...it wasn't all that expensive when I got to use coupons.
My upgrade to the prototype might be magnets instead of hanging on a pole--not sure yet though.
Thank you so much for the info! I did a quick search: (broken link removed to https://www.joann.com/aluminor-thermal-fabric-10-yard-bolt/zprd_14898621a.html)
I own a small dog accessories company, so I already shop quite a bit at Joann's, and can whip these babies up in no time :)
Magnets to keep them together in the middle would be nice. I wish our drapes had something like that.
I bet you could sew a little square of fabric on the backs of the curtain opening...about every 8-10 inches or so and tuck in strong magnets so that they "click together" when the curtains close.
My thought on magnetizing mine is kind of the same idea--but I'd paint the magnet white to match my window frames and then hot-glue them on. The magnets on the quilty fabric would be in a little pocket corresponding to the ones on the frame.
I'm still ruminating on it...
Reactions: SpaceBus
Would spots of velcro also work?
Reactions: SpaceBus
True. I bet it would work. My only objection to Velcro is that it tends to wear out after so long. I replace worn out Velcro fairly often on my hubby's fireman's gear....some places repeatedly. But if the wear and tear will be minimal, then sure it'd be fine.
Reactions: SpaceBus
this is one of the best threads i've read in a long time. thanks for the inspiration @ispinwool
Well...thought I might do a wee update...
I took the window quilts down today as I'm extremely hopeful that the cold is over.
Since I was able to keep a fire going almost all the time, (if I hadn't had the window quilts I wouldn't have even bothered to light it on the colder days...the heat would seep right through the windows) our heating bill was reduced by almost half!
Now that I've got the heat retention issue figured out, I'll need to work on getting more heat distribution. The living room (farthest from the wood burner) is pretty chilly since the furnace doesn't run as much.
All in all I'm glad I made them. Too bad I didn't think of it sooner.
