I have an early EPA stove fitted with secondary air. Fabco Pioneer Z. As built, it’s supposed to be around 60% efficient at 20k BTU per hour output.
It’s difficult / near impossible to find documentation. My stove seemed to have some insulation material at the top of the steel baffle that were damaged / removed by chimney sweep.
I repaired this by adding a combination of an additional superwool board as well as superwool insulation material, both from Lynn manufacturering. I don’t think this constitute as modification, but more like repair with best available material. Perhaps it was an upgrade because such flexible and refractory insulation material were not widely available in 1990.
From an engineering prospective, insulating the firebox promote efficiency and clean burn via secondady combustion but the downside would be potential for overfiring and increased firebox temperature. Through diligent monitoring, I’ve noticed the following changes this season compared to last season.
1. Significantly improved ease of lighting my stack on fire and quicker increase to temp. I always do top down and find the fire getting up to temp when the blower would kick on. I notice the blower would kick on when stove top thermometer reach 400F or so.
2. Significantly improved heat output per amount of wood burnt: we’ve been burning softwood, mostly pine. This shoulder season, 8-15lb of wood have been absolutely roasting us out. I have a heatpump with specific output so with the help of AI I was able to calculate efficiency via knowing the BTU it takes to raise my home temp. Around 7lb of wood burnt took home temp from 71 to 75 in a 10 foot ceiling, 1500 sqft space with massive windows and efficiency was calculated to be 73.5% at 20k btu per hour. Per name plate, this unit’s efficiency dipped below 60% at this output.
3. Smokeless chimney from very early stage of the burn. I used to see smoke from time to time. Now days, Thermawave / thermal shimmer is visible with zero smoke from around 10-15 minutes into the burn cycle. I always burn top down.
Overall, very satisfied with the repair of my stove and restoration of insulation material on the firebox.
My favoriate comment is from my wife. She acknowledges that our home is finally cozy with the heating output.
![[Hearth.com] Successful upgrade/restoration to 1990 EPA Fabco stove improving efficiency from 63 to 73% [Hearth.com] Successful upgrade/restoration to 1990 EPA Fabco stove improving efficiency from 63 to 73%](https://www.hearth.com/talk/data/attachments/350/350674-d5c931f18112597a0806b0d5e31a1f15.jpg?hash=ah3y74TPyD)
