I recently had a home built, and i had the builder add in a wood stove pipe to the existing design for the fireplace in the family room.
As a result my chimney includes the additional piping for the wood stove i would eventually like to add in my unfinished basement. The opening down there in the basement is 8", and I am told that I can use stoves requiring either an 8" OR a 6", not sure how accurate that truly is.
The basement area is approx 1500 sq ft, unfinished for now, and I really do not care if the room elevates to 100 degrees, my main concern is trying to get the heat to radiate into the first floor at least.
The first floor is approx 1500ft, and so is the second. Each floor has its own HVAC unit.
I grew up with a wood stove and I know that getting the right unit in place will likely keep the entire home comfortable; we would relish the notion of 90 degrees on the first floor
Looking for any thoughts on what I should consider....the picture is bad, but all I currently have to show the location intended, its at the very end, and you can barely see the hole for the stove near the top of the ceiling.
Some pics for perspective
