Hi
I've recently installed a 36" direct vent fireplace in my basement and before I enclose the wall surround with drywall I'm concerned the existing structure may be a fire hazard. The 42" LCD TV will be hung on a typical swivel mounting bracket. The surrounding F/P structure is made up of a combination of steel studs and 1/2" cement board. Right now I've installed 1/2" plywood between the 2 steel studs directly above the F/P, but after a couple hour burn last night the plywood and surrounding area got very hot. You can't see in the picture, but I've lined the back of the plywood with 1/2" cement board and all this is approx 2" away from the steel chimney vent. I'm wondering if I removed the plywood and just installed a couple horizontal pieces of steel stud between the uprights, this would be sufficient to anchor the TV mount?
I look forward to your suggestions.
THX
THX
as/Builder/Specs_bgd36ntr.html)
