Headline... Did I make a $7k mistake???
In October I had a Fusion 24 installed. Since then I have been doing every possible thing I can think of to get any real effect from this unit...
The unit is just not heating the room past a 5 foot radius, and in total after 10 hours of steady burn the space only increases a degree, yes 1 degree.
Here is what I have tried....
- Wood is at 13% moisture level
- Fire is built according to directions, reloads have gone from just one log to several with no change
- supplemented airflow with fans (both small and large) pointed at unit to force hot air into the room
- IR is showing in range of 600 about two hours into burn
- damper is set the mid level, in the slow level no real "fire" on the fast level results don't improve and I'll burn though a firebox of 8 logs in about an hour
I had the unit installed, but they didn't insulate around the unit. There are gaps between the sidewalls of the unit and the masonry bricks. Unit was supposedly installed with an insulated liner.
Would appreciate anyone's thoughts on what could possible be the issue.... I have reached out to the installer, but sometimes y'all have feedback I didn't think about!
