Hello everyone! I just joined a few weeks ago. This site has so much valuable information and is a MUST for anyone whom has a stove.
OK.....so here is the scoop. I called a dealer in NY....live in NJ. My wife was set on the Napoleon 1402. We also are having the dealer install the stove.
I spoke to the dealer and mentioned my dimension's. 30"wide 26"high 18"deep He asked what is the measurements at 14"? I have 22" wide at 14". He said that they would cut out the wall and he would have a mason fill in the wall to accommodate the stove. As I figured it was a alteration that is possible as I am not an expert.
Installer comes to install the stove.
Liner install:
Liner 6" was snaked down a 9X12 flue but ran into a bend in the flue. He was unable to get past the bend so he went in behind the fireplace and poked a 6"x8" hole in the block and flue. He was able to move the liner down but also ran into a issue with the opening to the fireplace. The top was a little small so he went in behind and jack hammered out the brick/flue that needed to be removed to install the liner. He filled the openings in the back with fireplace insulation and that mortar rated for 3,300 deg....said it costs $200 a 5gal bucket. He put about a 1-1.5 inch layer over the fire blanket. (don't know if this is the right thing to do...????) Might I add it took the better part of seven hours to get the liner in. Still the liner was not all the way to the stove, just to the top of the firebox with no movement up and down...the pipe was lodged in the opening preventing movement. The installers said they would put a couplings on and this will be OK. I asked when it comes time to pull the stove would I have issues? Will I have to hire a installer to put the stove back in? They said it would not be a problem.
Wood stove:
So the installer takes the stove off the truck. It appeared strange that the installer did not measure before the job. The just started working on the install and then when it came down to installing the stove then they measured. (what have I got myself into I said) The owner of the company whom sold me the insert said this can be done...taking 1 1/4" off each side by jack hammering the firebox. The installer said he had no idea that this was what is needed. This stove is not going to work. So they loaded the stove on the truck and left.
OK....so now I am pissed beyond belief. I ordered wood...split some rounds that I had for years. I was ready for my first burn and it was a total let down. Not to mention that I had a fireplace that was hacked at and left with just a liner and not insert.
My main concern is safety. Is this installation sound like it is safe? I was a masons helper so I had some insight, but nothing in regard to the install of a insert. We neve had to alter a firebox as they were new construction.
Can someone review and give me some tips or suggestions. Can this 1402P be installed safely by altering the firebox? Is the holes in the back of the fireplace with fire blanket and high heat mortar safe? I told them to rebuild the portion that would be taken out with fire brick. That was my take.
I am in NJ.....I don't want a stove install that is not up to code. OH....no mention of a permit for this work. They just came and started installing. Is it needed in NJ? Anyone an installer from NJ or had experience installing a stove in NJ? Did you have to get a permit. Licence....is one needed to install a stove in NJ? I know I should have looked into this...but being a first time stove buyer and not having any knowledge I was not aware of this.
The installer said he would be back next week to complete the installation. Should I even let him in the door?
Any help would be a big help. My wife is ready to kill me now.
Thanks Mike
Pics.....
(broken link removed to http://picasaweb.google.com/mskowalik/20101110?authkey=Gv1sRgCPCYwbrel8Sz7gE&feat=directlink)
Liner install:
Wood stove:
Thanks Mike
Pics.....
