The Amazing Free Flow stove is back - be the first to have something truly different!
How much do those stoves cost? Very modern looking but really just a barrel with tubes?
If those tubes surround the fire box then there must be no refractory on the sides to help keep the burn hot. I bet you must let in a lot of primary air to make it burn hot and clean. Does the thing even have a secondary burn?
cost and specifications located here...
(broken link removed to http://www.ofenseite.com/Bruno-III-with-21-KW-Stoves-Woodburning-stoves)
Not that efficient...
Bruno III with 21 KW
The Bruno convection stove, depending on the particular configuration, is well suited to provide cozy warmth for several rooms or even entire levels of your home. Using a secondary air-inlet, it reaches an efficiency of 75%. Due to the nearly complete burning of the wood, ash disposal is unproblematic and less frequently needed. The convection stove has no grate, and therefore, no ash pan. Combustion takes place solely on the ash, which should be maintained at a height of 5 ? 15 cm. In general, it will be necessary to remove this with a small shovel 1 -2 times per month. Noteworthy elements are the large loading door and viewing area, which even in the Bruno 00 has a diameter of 35 cm.
A full range of accessories
Anterior flue
Extremely large combustion chamber
Daily ash pan cleaning unnecessary
Quick and efficient room heating
High efficiency and low-emission burning
Universally suitable, for example: apartments, workshops, storehouses, or vacation homes
Delivery: throughout Europe
Technical Data
Heat power:
Efficiency:
CO2 emission:
Wood consumption:
Waste gas temp.:
Conveyor air presure:
21 KW
75 %
0,3 %
6,2 kg/h
310°C
12 Pa H / W/ D :
Room volume:
Flue size Ø:
Net weight:
Max. log length:
Door size:
Flue hight: 86 / 67 / 130 cm
600 m³
150 mm
180 kg
100 cm
35 cm
67 cm
European standard:
CE sign:
Fuel:
Glass door:
13240
yes
wood, briquets
yes
Delivery period:
Delivery charges:
Warranty:
Delivery:
1 week
EUR 85,00
2 years
agreeable
Why it's GREASED LIGHTNIN'!!
[Hearth.com] The Amazing Free Flow stove is back - be the first to have something truly different!
I dunno man. Some of you guys are die hard traditionalists.
I think it looks kinda cool, almost (gulp) cute. Certainly racy. Vroooom vroooooom, ahh s__t, it's not an engine, that's a chimney fire.
Definitely LOL literally from some of your comments. It's a good thing I wasn't drinking coffee when I read "minor modifications" and "flex tube" and "people seem happy in the pictures".
Thanks Miko! It's great to know that I'm not just amusing myself. :lol:
I actually think it's quite cool too, reminiscent of an Elm Stove (look that up), which I think is gorgeous. Too bad its functionality is somewhat doubtful.
certified106 said:
BrotherBart said:
Future hearth.com thread.
"What if I attach flex pipes to the tubes and extend them into the bedrooms upstairs?".
Almost spit my coffee at the computer screen while laughing after reading this one.....
For a small extra fee they will probably offer fans for each tube that could help move the air to where you want it. :)
Hehehe... headers standard, long-tube headers optional, and turbo chargers optional as well.
Pricing is in British Pounds or Euros so what is the conversion and also, it says it is available in all of Europe, are there distributors here in the US? I think they look cool and modern with a utilitarian bent to them.
That is nuts, love it!!!!!
BB, do you visit thereifixedit?
ThereIFixedIt is a regular destination for me. I get some of my best ideas there--TV floating on an inner tube in the pool, home air conditioner in a car window, etc.
It looks like the Grate Wall of Fire has a competitor!
(Curious) George said:
The site is full of pretty pictures, with only one item under technology--talking about how fantastic those convection tubes are--they make physics work for you!!! Nothing about burn technology, specifications, output, clearances, etc. I think that says it all.
I had friends back in Germany that actually used such a Bullerjan in their store. It was quite large and this stove heated the store in no time. They also had one at home and I'm a big fan of this Bullerjan, cause I know it works great. They put pretty much everything in there that burns and there was barely anything left. Clean out was quick also.
But I have to agree with you, the homepage is really bad when it comes to specifications and data. I was searching the web and all I could find was this here:
(broken link removed to http://www.bullerjan.com/web/Bullerjan-INDUSTRY/typ05_NZM.html) <- (this site is in German, I can help you with translation)
(broken link removed) <- (unfortunately a Czech page, but maybe the numbers will help?)
http://www.holzofen-verkauf.de/bullerjan/default.html?info_engl.htm
Model 00 01 02 03N
thermal power (TVJ) 6kW to 11 kW 14 kW 20 kW
depth - the stove 62 cm 71 cm 85 cm 114 cm
width - the stove 53 cm 63 cm 67 cm 67 cm
Height - stove 65 cm 68 cm 81 cm 81 cm
Weight 63 kg 83 kg 117 kg 187 kg
combustion chamber depth of 40 cm 50 cm 60 cm 60 cm
throat diameter of the flue 12 cm 12 cm 15 cm 15 cm
throat height of the center flue 48 cm 51 cm 62 cm 62 cm
diameter of the outer tube 5 cm 7 cm 7 cm
torsion spring (it is only necessary in case of multi-fold stack casting) YES YES on this model is not used
gas flow rate sucked on TVJ (unit g / s) 9.2 17.3 14.5
pg / max. flue gas temperature ° C 262/325 304/354 335/377
chimney mbar 0.10 0.11 0.11
chimney at 0.8 xTVJ - unit: mbar 0.08 0.09 0.09
CO2 content in% 6.5 6.7 9.1
efficiency in% 70.3 70.5 70.6
JTV Rated output [kW] 6 11 14
Gas flow relative to JTV [g / s] 9.2 17.3 14.5
AC / max. flue gas temperature [° C] 262/325 304/354 335/377
Chimney draft [mbar] 0.10 0.11 0.11
Chimney draft at 0.8 xTVJ [mbar] 0.08 0.09 0.09
CO2 content [%] 6.5 6.7 9.1
TECHNICAL DATA VOXKA
model Voxka 00 01
thermal power (TVJ) 6kW to 8.9kW to 17.8kW 11 kW
depth - Stove 65 75
width - Stove 50 68
Height - stove 60 78
weight 63 kg 117 kg
combustion chamber depth of 40 cm 49 cm
Throat diameter flue 12 cm 12 cm
hrdlaodvodu flue height of the center 48 cm 66 cm
Diameter outer tube 5 cm 6.3 cm
Power [kW] 8.9 17.8
Mass flow of gas relative to JTV [g / s] 9.2 17.3
The average flue gas temperature [° C] 325 354
Delivery pressure [pa] 10 11
CO2 content [%] 6,5 6,7
Efficiency [%] 70.3 65.4
Efficiency [%] 70.3 70.5 70.6
TECHNICAL DATA Bullerjan dot ®
Bullerjan dot ®
Rated 6 kW
Efficiency 80%
The flue gas temperature 184 K
7.17% CO2
CO 1229 mg / Nm ³
128 mg NOx / Nm ³
CnHm 83 mg / Nm ³
Dust 28 mg / Nm ³
Heat output 6kW
Depth of stone
652 mm
Width 667 mm stove
Height 910 mm stove
Weight of stove
160 kg
stand 25 kg
Stoves + stand 185 kg
Packaging - Wooden crates
25 kg
Packing unit 210 kg total
Total Package Size
86 cm-depth
-width of 77 cm
-height 115 cm
The data for sizing the chimney
Nominal heat output of 6kW
Mean weight of gas flow 7.5 g / s
Mean temperature of the flue socket 230 Ëš C
Minimum output pressure at rated power 0.12 mbar
Rated output according to DIN EN 13240
wooden logs
Nominal 6kW output
Efficiency 80%
7.17% CO2
WHAT 1229mg/Nm ³
Nox 128mg/Nm ³
CnHm 83mg/Nm ³
Dust 28mg/Nm ³
lignite briquettes
Nominal 6kW output
Efficiency 80%
The flue gas temperature 214 K
8.05% CO2
WHAT 663mg/Nm ³
Nox 169mg/Nm ³
CnHm 32mg/Nm ³
Dust 38mg/Nm ³
Connection
Diameter 150 mm flue neck trailer
An external diameter of 100 mm combustion air
The lower edge of the external combustion air 215 mm
The median height of 750 mm flue connection socket
The lower edge of the throat 670 mm flue
Safety distances
rear 250 mm
200 mm Side
In the area of ​​radiation 800 mm
Stoves are shipped only with stand!
