Hi. I just got a lopi Rockport 22’ and am hoping to install into the side of a chimney running up from basement that is currently encased in Sheetrock. The problem is that the wall adjacent to where I’d like the double insulated pipe in is tight and while it could go into the chimney with 6” clearance to the back combustible wall, the actual space is only 18” wide. Lopi suggested I look
Into the insul flue but that needs 19” for the front plate which is too big my question is can I use some other strategy to go through the dry wall or is there a way to do this with a reduced clearance to the back wall if I remove the drywall covering the brick chimney. I’ll be putting a steel liner in the chimney.
![[Hearth.com] Thimble for close clearance [Hearth.com] Thimble for close clearance](https://www.hearth.com/talk/data/attachments/350/350515-80b9ee8893920ebe7a05a8210e86b03d.jpg?hash=wFnPVC5OdK)
![[Hearth.com] Thimble for close clearance [Hearth.com] Thimble for close clearance](https://www.hearth.com/talk/data/attachments/350/350516-aab8d0d67cf2f217d8a76785bbbe9820.jpg?hash=wvr0MELzGv)
![[Hearth.com] Thimble for close clearance [Hearth.com] Thimble for close clearance](https://www.hearth.com/talk/data/attachments/350/350517-32372fd2d1da117828c80726b9d546ee.jpg?hash=4Vg27hiO5F)
![[Hearth.com] Thimble for close clearance [Hearth.com] Thimble for close clearance](https://www.hearth.com/talk/data/attachments/350/350518-a5ee01c5fc344a41aac4f2cee5e91b3e.jpg?hash=tqDv81Cxbb)
![[Hearth.com] Thimble for close clearance [Hearth.com] Thimble for close clearance](https://www.hearth.com/talk/data/attachments/350/350614-d75f873fdef22a7f1d00deedf2f0c5b8.jpg?hash=LoxhsHlMHp)
![[Hearth.com] Thimble for close clearance [Hearth.com] Thimble for close clearance](https://www.hearth.com/talk/data/attachments/350/350655-3832aee8ac59f96b96c5107b32b5020f.jpg?hash=w5eL1tqq5L)
