Permits, code and cold air intake vents
The 90 degrees is/was the pro installers plan @BKVP
You should use the 2 black double wall stove 45' back to back. I don't think I've ever 45 elbows in Class A, so that has to be a single 90.
BKVP
For getting around the eves, there are 30 deg class A.
But after coming through the wall, indeed a 90.
Reactions: BKVP
The stove will put out xxxx buts per hour. The house will loose yyyy buts per hour. Your choices are burn more wood and or sire seal and insulate. The spiral stair case will be the convective loop. I speak from experience standing eye level with the floor you will feel the air currents. As you walk stout you can see where the hot up parts are and the cold down.
Your soap stone won’t make a hill of beans difference. Just burn two more splits a day and save the labor and bee warmer.
To be clear, a OAK cannot rise above the floor of a woodstove firebox. And you drawing is just fine...
BKVP
I just remeasured outside where the vent will go. There is an 8 inch step up from the door when you exit through to the outside. I can not use the OAK. I will be selling it.
Hopefully the permits will be approved soon and I can have the stove installed, duct moved, and everything inspected before those global warming lows hit us. It might get as cold as 40 degrees in New England this season. Hah.
