Hi,
I am days away from construction. I am having a window closed off in my basement. My house is a level in, level out. The ground is level as you walk in the front door to a first and only floor. There is an attic above. Then you walk down a spiral staircase cut in the floor right next to that front door. Then walk to the back door and you are under the back porch and the ground is level out the back from the back door. The transition from the front to back on the sides of the house have half of the basement walls on both sides under ground. The top half are windows. One side has windows the length of the wall front to back. The wall on the other side has windows covering half of the wall. The furnace room is on the front quarter of the basement. That is using the other half of the wall. On that same wall, I am higher if someone to close one of those windows. Frame it with studs on the inside, plywood, then cinder block to match my outside basement wall. I am probably going to use rock wool for insulation, then plastic barrier, then sheetrock or cement board. I know cement board is not needed as I have everything for a wall shield installation with spacers and all for a corner install. I paid for the stove with an OAK. The stove has arrived at the dealers and have contacted me for an appointment for the installation. I am ready.
For some reason, I looked up information about the cold air return vent for my heating. It is just across from where I want to put the stove, 5 to 6 feet away in my basement. On the other side of that wall is a room where the furnace is. I figure great. Flip that on to get warm air upstairs easily. That’s a no no for code and will not pass inspection. I was hoping a OAK would fix this, it won’t. It needs to be at least 10 feet away. There are three other returns upstairs. I can just seal the downstairs one, but I think it is important to help move the air around the whole house, and not stress the blower. Also, I want to have the thermostat wired so I can turn on the blower in the summer to get that cooler summer basement air upstairs, and the warm air from the stove upstairs easier. I will have carbon monoxide detectors installed everywhere.
I did have someone come out from the dealer to look everything over because I need to know where the thimble would be placed to not have the framing in the way when the window is closed off. They measured inside where the stove would go, distance to combustibles, and outside where the chimney would go. They said they will have to drill through the eve of the roof to keep the pipe straight.
Nothing about the cold air return vent came up. In their defense, I think they were there just to measure the chimney exit and placement. As I think about it, I think I would like not to got through the eve, and use two 45 degree elbows. Thoughts?
The stove company did apply for a permit for the install on October 26th. I called the town permit office this past Tuesday Nov 24th to ask about adding to the permit to change the vent location. Just at the end of that wall, around the corner next to a door to enter that room. That will place the vent 10’6” to 11’ from the stove. I did have an hvac pro come take a look before I called the permit office. I think they added it, I then found out that nothing has been approved yet. I have no permit. It is still going through whatever they need to do. Should it take this long?
Do you have any suggestions about any of this?
Thank you.
Thank you.
