Awesome site! So glad I found it.
I have a Vermont Castings Intrepid wood stove (1980 model) that I bought used and refinished. (broken link removed to https://www.stovesandspas.com/pdf/intrepid.pdf)
I installed it in an existing fireplace in my living room using the Ventinox direct connect kit. http://www.protechinfo.com/VENTINOX-Direct-Connect-Kits-c252.html
It worked great from the start, but has developed a strange noise over time. It "ticks" when not in use. The tick sounds almost like a grandfather clock. It occurs most frequently when the stove is cold and the damper is open with the doors shut. The noise is still there, but quieter when the damper is shut with the doors closed (cold stove). The noise goes away when the stove is in use or if the front doors are slightly ajar when the stove is not in use.
The noise sounds like it's coming from the back of the unit near the exhaust outlet (top of stove). Almost like someone is gently tapping the stove with a screwdriver to keep time.
Something is probably loose internally? Please help!
Thanks!
Thanks!
