7000# GVW. I'm not a fan of 3500# axles so I wouldn't think twice about using 6000# axles. It's too easy to bend a 3500 axle.
16' dual 3500 with brakes and a reinforced ramp gate. Will do just about anything you need and/or your tow vehicle will handle. Firewood is heavy...single axle trailer isn't much better than hauling in the bed.
edit: I gotta ask... why not a single 5200 lb. axle? Seems like that would be the best compromise for all my needs. Could handle the tractor or mower, a decent amount of firewood, and could still be used on the lawn without tearing things up. Did I mention I have a lot of lawn?
Things get pretty hairy pretty quick when a single axle has a blow-out...I would hate to haul my high dollar equipment on one...or have my tow vehicle drug into a ditch when hauling a heavy load of wood.
Even though you might not need the length of a tandem for hauling wood, you do need the capacity and redundancy they offer. My opinion...
Any recommendations?
![[Hearth.com] Time to buy a trailer? [Hearth.com] Time to buy a trailer?](https://www.hearth.com/talk/data/attachments/84/84192-7d8cf73a5099e4dcdad5029c80dc1d35.jpg?hash=pd6b6ZlaUw)
So, I have access to all the free wood I ever need, but it's located about 9 miles from my house. I've tried everything for moving it over the last year... a half-dozen trips in one day with my pickup, renting a trailer, borrowing a trailer...
A lot of that wood is BIG stuff, as in rounds bigger than 40" diameter. This is because the guy who owns the wood lot processes the small stuff for himself and a neighbor, and leaves to me anything too big for him to handle himself. That means rounds that require a tractor to load and unload from a pickup (no problem... got that). The few times I've used a landscape trailer with a drop tailgate, I've found it pretty easy to roll these big rounds right up the ramp onto the trailer, and then back down again when I get home. A trailer, even a light one, can also haul more weight than my Ram 1500 pickup.
So, I start asking around, and it seems the going rate for a single-axle landscape trailer is about $1000, depending on size. Then I start thinking, if I'm going to lay out for a trailer anyway, maybe I should get something that can haul my tractor or mower. Mower is a JD 757 ZTrak, only about 1200 lb., if I recall. Tractor is a JD 855 with 52 FEL, roughly 1900 lb. unloaded, or 3000 lb. carrying the front end loader and ballast.
I suspect the need to move the tractor and mower would be more often for service than for hauling the tractor with implements somewhere to use it, so my current thinking is get a single-axle trailer that can haul at least 2000 lb., and just rent when I need something heavier.
Any recommendations? The weight of the big rounds I haul adds up quick, with only a dozen rounds often putting the average landscape trailer overweight.
BTW...if you find any used trailers that are older than a 7 or 8 yrs old, figure your pricing on installing new brakes. just seems like anything used I've found, needs a complete brake job.
