There is a couple of stoves on the "local" CL right now. A PE Summit and another Lopi (not sure of model).
After 3 years of harping, I FINALLY got my mom to put a stove in her house. She lives on a lake and her house is FREEZING in the winter, plus she pays through the nose for heat (not like you guys out east, but not cheap either). Lopi Republic 1750 (used). I have no clue what her wood consumption will be per year, but I have about 8-10 cords cut/split at her place.
I heat my garage with a Clayton 1400 and end up going through 4-6 cords a year in that thing. It is WAY over-sized for what it's heating, but the plan is to eventually punch the garage out to a 26x40 for shop space.
The question is....should I put a stove in my house. The house is a 26x40 rambler with a full finished basement. Currently it is just me living in it and I'm dang sick of freezing (last year I would go out to the garage and read etc at night to get warm). I have electric forced air heat upstairs with propane "off peak" and electric baseboards in the basement.
Electric bill goes up about $150-$200 in the heating season (dead of winter) and I go through about $220 worth of propane a year to boot.
Several concerns/thoughts...
1. not sure I want to cut another 4 cords or so a year.... Currently I am clearing out a shelter-belt about 30 miles from my place, all Ash and it should be a good source for at least another 3 years worth at 10 cords a year. I hand process my wood...
2. Don't have much more in storage space for wood for the house.
3. Consider anything with longer than a 3 year payoff (stove and chimney only) not really desirable. Cost needs to be ~$1200 tops for entire system.
4. Upstairs install vs. downstairs. If I go upstairs, a hearth pad is about $200 and that would be about the same as the additional chimney needed for a basement install. I have more room in the basment family room. The PE summit would heat the whole house from the basement but probably cook me out with a upstairs install. Then you have the hauling wood downstairs thing...
Thoughts anyone?
Thoughts anyone?
I think you've answered your own question. You should put a stove in the space where you want to live. If you don't spend a lot of time in the basement, there's no point in putting a stove down there. OTOH, heat doesn't want to travel downward, so a stove upstairs isn't going to do much for the basement. OTOOH, dep on insulation, basements tend to suck up a lot of heat, so a basement stove might not heat the upstairs the way you hope it will, esp if the stairs are not in the same room as the stove. Are you planning on using an existing masonry chimney? Either install would probably require a chimney liner for best results. . .$400+ for liner pipe.
