I've been reading various threads in here about chimney liners and i'm wondering about the benefits. If you cannot use cannot fit an insulated liner in the existing chimney is there any benefit??. With the flex liners, is it hard to brush with all the ridges??. If I can fit double or tripple wall rigid in there would that be better than insulated flex (if it would fit)??.
I've got a pretty tall chimney (two story house on a 12-12 pitch roof and the chimney is just off center of the house), I run a Jotul firelight and burn 24/7 until spring. I typically sweep the chimney once or twice a year and generally get 3 or 4 gallons of creosote out of it. It draws real good when hot and it's hot more than not. I "think" it's an 8x8 clay liner all the way to the top. With this basic info, would it be worth it to put a liner of some sorts in it???. A typical morning, when it's at it's coolest, the stove top temp is 300-350 and it may take an hour + to get it back cranking to 500-525 (which is all I need to cook us out). Would it be a waste of money or would it make a noticeable difference in performance and creosote buildup??. I don't know anybody who runs a liner in their setup but it sounds like many in here do.
hh: ). It's basically a masonry chimney inside a bigger masonry chimney. I thought by doing it that way, having an air pocket between the chimneys I was doing the right thing (I should have done tripple wall rigid liner right from the get go though).
