Harvey Schneider
Here is a very brief explanation of relative humidity. It basically is a measure of how much of the air's capacity to hold moisture has been filled. That capacity changes with temperature.I guess not, I have a digital instrument that measures outside and a few other manual ones that measure inside.
View attachment 124359 View attachment 124361
An example below.
The air has the same amount of moisture in it before and after it is heated. If the air outside at 10 degrees, for example, has 70% relative humidity, when heated, it's capacity to hold moisture increases. Because of that, it's relative humidity drops (to, perhaps 30%). It still contains the same amount of moisture, it's just that it could hold more. It will take that more from wherever it can find it; from the furniture, from house plants or from you.
When you say a combustion fan pulls 80 cfm would that be with the damper wide open? For example my damper is only open about 1/2" so am I pulling in 80 cfm of air or 20 for example?
